A Error of pointer
A Error of pointer
wackestar
unsigned int FlashBuf[10];
#pragma CODE_SEG NON_BANKED
void FlashProg(void)
    FSTAT = 0x80;
    while(!FSTAT_CCIF);
void  FlashInit(void)
    unsigned char i;
   unsigned int * far  pSData = (unsigned int * far ) FlashProg;
    FCLKDIV = FBUS / 200000;
    pSData     for(i = 0 ; i < 10; i++)
         FlashBuf[i] = *pSData++;
I hope to copy FlashProg code in FlashBuf,But the pSData is error.  Why?
CrasyCat
Specialist III
Hello
I am not sure what you are trying to achieve here.
Are you looking for a way to run some code out of RAM?
If this is the case I would suggest you to look for FAQ-27682 on Freescale web site.
This FAQ covers exactly that topic.
I hope this helps.
CrasyCat
CrasyCat
Specialist III
Hello
I hope this helps.
CrasyCat
