68HC11 Monitor Program to work with CodeWarrior Source Level Debugger
3,450 次查看
HK168
I am a new user of CodeWarrior IDE platform. Here are my questions
[1] Which 68HC11 EVM or EVB would you recommend for me to practice with CodeWarrior source level debugger. The cheapest option is better and how much you think it will cost?
[2] Where can I find a 68HC11 monitor program to work with CodeWarrior source level debugger?
Thanks in advance.
标记 (1)
2,109 次查看
CrasyCat
Specialist III
Hello
Originally we tested CodeWarrior for HC11 on following Freescale evaluation boards:
    M68HC11EVS
   M68HC11EVM
   M68HC11EVB
   M68HC11EVBU2
I have no clue which one of these boards are still available for purchase.
Source code for ROM monitor are delivered with CodeWarrior for HC11. Look at directory {Install}\Monitor\HC11c.
Also if you are using your own board, look at {Install}\docu\HC11\manual\Manual Small Monitor HC11.pdf.
Section "Porting the Monitor Program to your Own Hardware" provides info on how to achieve that.
I hope that helps a little bit.
CrasyCat
2,110 次查看
CrasyCat
Specialist III
Hello
    M68HC11EVS
   M68HC11EVM
   M68HC11EVB
   M68HC11EVBU2
CrasyCat
