xxxx bus error
xxxx bus error
5,624 次查看
zhouhuiying
hi,
when i download my code ,it cannot run shows "xxxx bus error" even if i create a new project with no code.
Although if i uninstall code warrior 2.10 and reinstall again ,the code runs normally. So what could be my problem?
4,700 次查看
TICS_Fiona
Hello zhou
The debugger configuration file "PPSetup.dsk" located in the same directory as the ICDPPCNEXUS application ("\pemicro\PPsetup.dsk" may be corrupted.  Simply delete this file.  The new file will be created automatically when the next debugger session is established.
Best Regards
Fiona Kuang
Technical Information & Commercial Support
Note: If this post answers your question, please click the Mark Correct button. Thank you!
