while installing code warrior V6.3 on PC (window 7, 64bit ), but failed , the remind is "failed to install windriver's kernel module code warrior"
1,178 次查看
andylong
1,002 次查看
ZhangJennie
CW6.3 is not designed for 64bit win7 platform.
if you work with HCS08 MCU, please use CW10.7 instead on 64bit win7.
CodeWarrior for Microcontrollers-Eclipse IDE|NXP
Jennie Zhang
