licensing
licensing
2,066 次查看
billunkel
I have been using
CW for
ColdFire V6.3
for long time, but now want to do images bigger than 128k.  I get message that my license does not allow.
What are the steps to proceed.
2,001 次查看
TICS_Fiona
Hello Bill
The Special Edition has 128K C code size restriction. You may get an evaluation license for CodeWarrior v6.3 for Coldfire which has no code size restriction, but has 30-day limit.
To get it, please submit a service request.
1) Go to http://www.nxp.com/support/sales-and-support:SUPPORTHOME.
2) On the bottom of the page under Submit New Issues, click Hardware & Software.
3) Register with your business email to access NXP technical online support.
4) A verification email will be sent to your account. Click the link embedded in that email to verify your access.
5) On the NXP online support page, select Contact Support from the top menu and click “submit a new case” to start the process.
To get the CodeWarrior without time or code size restriction, please purchase a CodeWarrior Suite. For the purchasing model, please refer to:
http://cache.freescale.com/files/soft_dev_tools/doc/fact_sheet/BRCWPPI.pdf
For the difference of Basic Suite, Standard Suite and Professional Suite, please refer to:
http://www.freescale.com/files/soft_dev_tools/doc/fact_sheet/950-00437.pdf
User can purchase it from Freescale website directly:
http://tinyurl.com/kwdt74f
Or can purchase it from distributors. You will be able to find the nearest distributor from:
http://tinyurl.com/vdru3
Hope this helps!
Best Regards
Fiona Kuang
Technical Information & Commercial Support
2,001 次查看
TICS_Fiona
Hello Bill
Hope this helps!
Best Regards
Fiona Kuang
