how to send build errors to a text file
1,267 次查看
daveklotzbach
When building a project, if errors occur, I need a way to capture those errors to a file to create a build failure report.
As far as I can see, these errors are directed to a window in code warrior and there is no way to copy them or to send them to an error text file.
Is it possible and how is it done?
Using Codewarrior for S12 version 5.2
1,198 次查看
ZhangJennie
Hi Dave
CodeWarrior 5.2 doesn't have feature of outputting build errors to a file.
I advise doing Ctrl+C when the "Errors & Warning" message window is ACTIVE.
 Then just do Ctrl+P in a separate file to paste all the errors and warnings.
Hope this helps.
Jennie Zhang
