how to fix the compiling warning of "function does return"?
3,890件の閲覧回数
xuedongyang
Hi, NXP experts,
I observed compiling warnings "function does return". Any idea why we got the warnings and how to fix it?
Xuedong Yang
3,820件の閲覧回数
kef2
Senior Contributor V
Pretty simple one. You claim your function doesn't return __noreturn, and function actually returns. No forever loop inside. Either add for(;;){} at the end or remove __noreturn.
4 返答(返信)
3,821件の閲覧回数
kef2
3,810件の閲覧回数
xuedongyang
Thank you very much, for the suggestion.
3,831件の閲覧回数
xuedongyang
Hi, Yiping,
Sorry for late response.
The version of CW I am using is 10.3.1. Here is the screen shot for the version and project. Yes, I am using NXP's project. I have not changed the linker file. Please let me know if you need more information.
Thanks.
Xuedong
3,870件の閲覧回数
yipingwang
Can you give me the version of the CodeWarrior you are using? Do you use the project NXP sent to you? Please give more details about the project.
Have you changed the file size and linker file? From the warning, I am more worry about the _memset16 cannot be reached than "function does return"
