how can i run a user command or app before compile
1,865 次查看
xiaochenqiang
Hi all!
 I am using the S12XEP100,the IDE is Codewarrior V5.1,
now my problem is that how can i run a user  command or app before compile?
thank you!
1,778 次查看
ZhangJennie
Can you please specify your question?
CW5.1 integrates pre-linker but doesn't have pre-compiler.
Jennie Zhang
1,778 次查看
xiaochenqiang
Jennie Zhang,thank you!I have found the pre-linker in the standard settings of the project,the pre-limker can sovled my question,but not very satisfied,because pre-link if after the compile or make,I want run the batchfile before the make or compile.
1,778 次查看
ZhangJennie
Hi Xiaochen.
You are welcome.
Currently CW for HCS12 doesn't have pre-compile feature.
I will escalate it as feature request to development team if necessary. Thank you for bringing this problem to our attention.
Jennie Zhang
