how can i run a user command or app before compile
1,816件の閲覧回数
xiaochenqiang
Hi all!
 I am using the S12XEP100,the IDE is Codewarrior V5.1,
now my problem is that how can i run a user  command or app before compile?
thank you!
3 返答(返信)
1,729件の閲覧回数
ZhangJennie
Can you please specify your question?
CW5.1 integrates pre-linker but doesn't have pre-compiler.
Jennie Zhang
1,729件の閲覧回数
xiaochenqiang
Jennie Zhang,thank you!I have found the pre-linker in the standard settings of the project,the pre-limker can sovled my question,but not very satisfied,because pre-link if after the compile or make,I want run the batchfile before the make or compile.
1,729件の閲覧回数
ZhangJennie
Hi Xiaochen.
You are welcome.
Currently CW for HCS12 doesn't have pre-compile feature.
I will escalate it as feature request to development team if necessary. Thank you for bringing this problem to our attention.
Jennie Zhang
