fopen()
fopen()
2,735 次查看
sachusanal
Im not able to use the function fopen in my bareboard project. Im using Codewarrior 10.6 version. Do i need to add any macros or is there any settings to be made to enable fopen() ?
5 回复数
2,524 次查看
ZhangJennie
hi Sanal
what chip do you work with?
do you use RTOS for example MQX?
Zhang Jun
2,524 次查看
sachusanal
Hi Zhang Jun,
Thanks for your support.
We are using MK20DX256VLL7 and not using any RTOS.
Sachu
2,524 次查看
ZhangJennie
hi Sachu,
IO function such as fopen can not work in bare metal  project.
You may want to look into RTOS solutions that may provide some sort of file I/O support. for example, MQX.
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=MQX
does this make sense?
Zhang Jun
2,524 次查看
sachusanal
Dear Zhang Jun,
     Thank you, i shall proceed with the same.
Sachu
2,524 次查看
ZhangJennie
you are welcome!
If this post answers your question, please click the Correct Answer button. Thank you!
Zhang Jun
