difference between CWP standard and Pro
prakashpatel
What is the difference between CWP-PRO and CWP-STANDARD license for Code Warrior studio.
Prakash
Jorge_Gonzalez
Hello Prakash:
The differences between licenses are related to the features available in the software, code size limitations, code types (C/C++), among others.
I do not know what architecture you use, but I think the attached document can serve you as reference.
Also, you can give a check to the table at the next link, just at the left side select the corresponding device and IDE version you are using:
CodeWarrior Development Suites
Hope this helps!
Regards!
Jorge Gonzalez
