did CodeWarrior 10.6 can create Components Library ?
3,940件の閲覧回数
neil_lin
how can I create processor components library ?
I want to use the Software simulation for MCU , thx for answer.
タグ(2)
3,711件の閲覧回数
ZhangJennie
Hi Neil,
yes, you can create your own Components with Component Development Environment (CDE).
CDE is an Eclipse plug-in tool that provides a graphical interface to create, edit, and package embedded components. It can generate initialization code, fully operational drivers or package a software algorithm.
You can create new components using the Component Development Environment. You only need to determine Properties, Methods, and Events and make the implementation of methods and events.
for its usage, please see these two documents under {your CW10.6 install}\MCU\Help\PDF
- CDE_userguide.pdf
- CDE_RTOS_User_Guide.pdf
Hope this helps!
this answer is for you. if it helps, please click on "correct answer" button. thanks!
ZhangJun
3 返答(返信)
3,711件の閲覧回数
ZhangJennie
Hi Neil,
- CDE_userguide.pdf
Hope this helps!
ZhangJun
3,711件の閲覧回数
Wlodek_D_
Senior Contributor II
Thank you for your post, however please consider moving it to the right community place (e.g. CodeWarrior Development Tools ) to get it visible for active members.
For details please see general advice Where to post a Discussion?
Thank you for using Freescale Community.
3,711件の閲覧回数
neil_lin
hi , Wlodek_D
thank you for your suggestion , I had move my discussion to the Codewarrior Development Tools community place .
Neil
