cyrillic with Codewarrior 6.3
2,258 次查看
cperez
I need to use Cyrillic words with WPC151 source, but I can't put this source in Codewarrior.
For Example. I need to compile this word.
НАСТРОЙКА
How I can use it??
Thanks in advance
2,170 次查看
ZhangJennie
Hi Carlos,
CW6.x does not support language packs.
CW10 itself doesn't support Russian either. but user can go to ( http://www.eclipse.org/ )
to find the additional language packs in Eclipse. only the strings localized (by the community) to Russian is supported.
Hope this helps!
Jennie Zhang
2,171 次查看
ZhangJennie
Hi Carlos,
Hope this helps!
Jennie Zhang
2,170 次查看
cperez
Thanks for your response.
I'ts clear.
2,170 次查看
ZhangJennie
You are welcome!
Jennie Zhang
