bool data type in Code warier
1,980件の閲覧回数
charudattaingal
Dear Team,
Code warier IDE bool data type is type-def to int by default.
so is taking more memory as com-pair to actual bool data type.
Is it standard bool data type is supported by code warier IDE/Library ?
Thanks & Regards,
Charudatta
1,725件の閲覧回数
ZhangJennie
Hi Charudatta,
_Bool is a keyword in C99: it specifies a type.
Codewarrior for hcs12(x) follows c90, it doesn't have bool type but is defined as a typedef in stdtypes.h
typedef int Bool;
if user think int is too memory consumming, user can modify it to
typedef char Bool;
does this answer your question?
Jennie Zhang
