What do these commands mean?
zheng
what do these commands mean?
ccs::run_core
ccs::all_run_mode
ccs::reset_to_debug
ccs::config_template 0 0x1001 5000
ccs::config_template 1 4096 0x80000001
who can give us some documents about CCS?
ZhangJennie
leon zheng
Please let us know your chip part number thus we can assign the right engineer for your question. Thanks
Jun Zhang
zheng
we use ls1043a/ls1023a.
yipingwang
ccs::run_core : Restart the execution (place in user mode) of a core to change the program flow, first write to the PC register of the core.
ccs::all_run_mode: Displays ccs::core_run_mode for each core on the chain.
ccs::reset_to_debug: Resets all devices connected to the specified command converter on the specified server and stops them at their reset vector in debug mode.
ccs::config_template: Increase the reset delay.
We suggest users use the Debugger Shell in CodeWarrior rather than CCS commands.
YIping
zheng
what are the meanings of paraments of ccs::config_template?
yipingwang
ccs::config_template <chain_pos> <index> <value>
Configure template index, the parameters inside the JTAG configuration file.
Yiping
zheng
what is the index?
how many items are in the index? and what are their definition ?
