VSPA NCO Formula & Parameter Mapping (LA12xx)
848件の閲覧回数
Fengsq
I’m currently working with the VSPA processor and have a few technical questions about the NCO instruction. This numerically controlled oscillator instruction is designed for complex sequence generation, as referenced in Chapter 4.21 of the LA12xx VSPA3 ISA reference manual.
I have questions about the mathematical formula for NCO output described in the official document. In the given formula, the initial phase variable (nco_phase) is placed within parentheses and multiplied by the frequency value (nco_freq).
For my application, I need to generate a signal following this standard complex exponential form:
2π × frequency × index + initial phase.
I would like to confirm the precise mapping between this standard formula and the two configuration parameters: nco_phase and nco_freq. Additionally, I need to know if a scaling factor is required to convert normalized floating-point values into valid 32-bit integer inputs for this processor.
Thank you for your time and technical support.
765件の閲覧回数
yipingwang
In fr1_fr2_test_tool there is the feature to configure NCO to send complex single tone at DAC sample rate with script send_single_tone.sh, for example,
./send_single_tone.sh 0 1000000 80 will send on antenna 0 with 1Mhz 80% scale single tone."
above command converts the 1MHz into the value to be set in NCO register, you can also see below description in in DFE_Ref_User_Guide.pdf,
Frequency factor =
4294967296*frequency/sampling_rate.
Frequency range from 1- 122880000Hz. Sampling rate=DCS sampling rate.
example: to send 1Mhz at sampling 491520000, freq_factor=4294967296*1000000/491520000 =
0x855555
Regarding phase, default is starting from 0. Each NCO iteration generates 32 complex samples for example, then phase increase 32*phase_step automatically
phase_new = phase_old + 32*phase_step
the phase_step is your tone freq divided by sample_rate
766件の閲覧回数
yipingwang
Frequency factor =
0x855555
%3CLINGO-SUB%20id%3D%22lingo-sub-2357118%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EVSPA%20NCO%20%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9F%E3%83%A5%E3%83%A9%E3%81%A8%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%20(LA12xx)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2357118%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%E7%8F%BE%E5%9C%A8VSPA%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81NCO%E3%81%AE%E6%8C%87%E7%A4%BA%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E6%8A%80%E8%A1%93%E7%9A%84%E3%81%AA%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%3E%E3%81%93%E3%81%AE%E6%95%B0%E5%80%A4%E5%88%B6%E5%BE%A1%E7%99%BA%E6%8C%AF%E5%99%A8%E5%91%BD%E4%BB%A4%E3%81%AF%E3%80%81LA12xx%20VSPA3%20ISA%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%AE%E7%AC%AC4.21%E7%AB%A0%E3%81%A7%E5%8F%82%E7%85%A7%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E8%A4%87%E9%9B%91%E3%81%AA%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%E7%94%9F%E6%88%90%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E8%A8%AD%E8%A8%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E5%85%AC%E5%BC%8F%E6%96%87%E6%9B%B8%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E4%B8%8B%E5%A3%AB%E5%AE%98%E3%81%AE%E7%94%9F%E7%94%A3%E6%80%A7%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E6%95%B0%E5%BC%8F%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%3E%E4%B8%8E%E3%81%88%E3%82%89%E3%82%8C%E3%81%9F%E5%BC%8F%E3%81%A7%E3%81%AF%E3%80%81%E5%88%9D%E6%9C%9F%E4%BD%8D%E7%9B%B8%E5%A4%89%E6%95%B0%EF%BC%88nco_phase%EF%BC%89%E3%81%8C%E6%8B%AC%E5%BC%A7%E5%86%85%E3%81%AB%E9%85%8D%E7%BD%AE%E3%81%95%E3%82%8C%E3%80%81%E5%91%A8%E6%B3%A2%E6%95%B0%E5%80%A4%EF%BC%88nco_freq%EF%BC%89%E3%81%A8%E4%B9%97%E7%AE%97%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E7%A7%81%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E6%A8%99%E6%BA%96%E7%9A%84%E3%81%AA%E8%A4%87%E7%B4%A0%E6%8C%87%E6%95%B0%E5%BD%A2%E5%BC%8F%E3%81%AB%E5%BE%93%E3%81%86%E4%BF%A1%E5%8F%B7%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E2%CF%80%20%C3%97%20%E5%91%A8%E6%B3%A2%E6%95%B0%20%C3%97%20%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20%2B%20%E5%88%9D%E6%9C%9F%E4%BD%8D%E7%9B%B8%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E3%81%93%E3%81%AE%E6%A8%99%E6%BA%96%E5%BC%8F%E3%81%A8%E3%80%81nco_phase%E3%81%8A%E3%82%88%E3%81%B3nco_freq%E3%81%A8%E3%81%84%E3%81%862%E3%81%A4%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%A8%E3%81%AE%E9%96%93%E3%81%AE%E6%AD%A3%E7%A2%BA%E3%81%AA%E5%AF%BE%E5%BF%9C%E9%96%A2%E4%BF%82%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%3E%E3%81%95%E3%82%89%E3%81%AB%E3%80%81%E3%81%93%E3%81%AE%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%AB%E3%81%8A%E3%81%84%E3%81%A6%E3%80%81%E6%AD%A3%E8%A6%8F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%E6%B5%AE%E5%8B%95%E5%B0%8F%E6%95%B0%E7%82%B9%E5%80%A4%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AA32%E3%83%93%E3%83%83%E3%83%88%E6%95%B4%E6%95%B0%E5%85%A5%E5%8A%9B%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%E4%BF%82%E6%95%B0%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%9F%A5%E3%82%8A%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E3%81%8A%E6%99%82%E9%96%93%E3%82%92%E5%89%B2%E3%81%84%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%80%81%E3%81%BE%E3%81%9F%E6%8A%80%E8%A1%93%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2358322%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20VSPA%20NCO%20Formula%20%26amp%3B%20Parameter%20Mapping%20(LA12xx)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2358322%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Efr1_fr2_test_tool%E3%81%AB%E3%81%AF%E3%80%81%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88send_single_tone.sh%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6DAC%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%83%AC%E3%83%BC%E3%83%88%E3%81%A7%E8%A4%87%E9%9B%91%E3%81%AA%E5%8D%98%E4%B8%80%E3%83%88%E3%83%BC%E3%83%B3%E3%82%92%E9%80%81%E4%BF%A1%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%ABNCO%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E6%A9%9F%E8%83%BD%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E4%BE%8B%E3%81%88%E3%81%B0%E3%80%81%3CBR%20%2F%3E%20.%2Fsend_single_tone.sh%200%201000000%2080%20%E3%81%AF%E3%80%81%E3%82%A2%E3%83%B3%E3%83%86%E3%83%8A0%E3%81%8B%E3%82%891MHz%E3%80%8180%25%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AE%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%83%88%E3%83%BC%E3%83%B3%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E4%B8%8A%E8%A8%98%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AF1MHz%E3%82%92NCO%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%80%A4%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81DFE_Ref_User_Guide.pdf%E3%81%AE%E4%BB%A5%E4%B8%8B%E3%81%AE%E8%AA%AC%E6%98%8E%E3%82%82%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%E9%A0%BB%E5%BA%A6%E4%BF%82%E6%95%B0%20%3D%3CBR%20%2F%3E%204294967296*%E5%91%A8%E6%B3%A2%E6%95%B0%2F%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AA%E3%83%B3%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%88%E3%80%82%3CBR%20%2F%3E%E5%91%A8%E6%B3%A2%E6%95%B0%E7%AF%84%E5%9B%B2%E3%81%AF1%EF%BD%9E122880000Hz%E3%81%A7%E3%81%99%E3%80%82%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AA%E3%83%B3%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%88%EF%BC%9DDCS%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AA%E3%83%B3%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%88%E3%80%82%3CBR%20%2F%3E%E4%BE%8B%3A%20%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AA%E3%83%B3%E3%82%B0%20491520000%20%E3%81%A7%201Mhz%20%E3%82%92%E9%80%81%E4%BF%A1%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81freq_factor%3D4294967296*1000000%2F491520000%20%3D%3CBR%20%2F%3E%200x855555%3C%2FP%3E%0A%3CP%3E%E4%BD%8D%E7%9B%B8%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%E3%81%AF%E3%80%81%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AF0%E3%81%8B%E3%82%89%E5%A7%8B%E3%81%BE%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E5%90%84NCO%E5%8F%8D%E5%BE%A9%E3%81%A7%E4%BE%8B%E3%81%88%E3%81%B032%E5%80%8B%E3%81%AE%E8%A4%87%E7%B4%A0%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%81%8C%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%80%81%E4%BD%8D%E7%9B%B8%E3%81%AF%E8%87%AA%E5%8B%95%E7%9A%84%E3%81%AB32*phase_step%E3%81%A0%E3%81%91%E5%A2%97%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20phase_new%20%3D%20phase_old%20%2B%2032*phase_step%3CBR%20%2F%3E%20phase_step%E3%81%AF%E3%80%81%E3%83%88%E3%83%BC%E3%83%B3%E5%91%A8%E6%B3%A2%E6%95%B0%E3%82%92%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%83%AC%E3%83%BC%E3%83%88%E3%81%A7%E5%89%B2%E3%81%A3%E3%81%9F%E5%80%A4%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
