Update for 9S12XF512?
dermotmurphy
I have loaded CodeWarrior Classic for S12X V5.2 which is the version to use for the #9S12XF512.
However, the software does not include the ability to create a project for the 9S12XF512 nor does it have the required files for this MCU in the lib\hc12c\src folder.
Is there an update package for the IDE and Processor Expert?
If not, how do I modify the installation to allow CW to create projects for the XF512?
dermotmurphy
Thank you for this.
Will V5.2 be updated for this MCU, or is this MCU not recommended for new designs.
V5.1 seems very buggy (PE crashes, IDE sometimes will not exit and must be closed using Task Manager).
What is the correct order of installing the service packs?
Dermot
ZhangJennie
Dermot
No plan to update CW5.2 for this MCU. This is a marketing decision
I suggest user install compiler patch first then in stall device service pack, then processor expert patch.
ZhangJennie
HI Dermot
CW5.2 doesn't support 9S12XF512. please use CW5.1 instead. processor expert support is also included.
Attached is instruction of how to download CW5.1.
Have a nice day,
Jun Zhang
