USB TAP and WinDriver
2,747 次查看
lucaprampolini
Goodmorning,
I have an USB programmer (Freescale USB TAP) for 16bit micro 56F800 and I don't know why, the programmer doesn't work because needs the windriver license.
It works a lot of years before and now stopped to work for this driver. The programmer is installed in a computer with Xp 32Bit and we use Codewarrior 8.3 version for 56800 micro.
I read some threads but I didn' t solve the problem. Could you help me please?
Thank you in advance.
Luca
4 回复数
2,533 次查看
lucaprampolini
I've understood that is a codewarrior license problem. Now I' ve still downloaded  the evaluation version and I' ve a license until 6 may but it ask me already this license.Immagine.bmp
2,533 次查看
lucaprampolini
I've found the USB TAP driver, but I've the problem again...
The Jungo Windriver ask me to pay but it didn't never ask me before..
2,533 次查看
lucaprampolini
Thank you xiangjun, I think that the main problem is that  I don't have the USB TAP driver. Coul you send me a Codewarrior usb tap driver like in your picture?
Thanks again.
Luca
2,533 次查看
xiangjun_rong
Hi, Luca,
As I said that the usbtap driver is located at the directory in the CodeWarrior for DSP56800E ver8.3 tools, you can insatll the driver manually:
C:\Program Files (x86)\Freescale\CodeWarrior for DSC56800E v8.3\ccs\drivers\usb
Pls follow up the picture to install the usbtap driver.
Hope It can help you
Xiangjun rong
