Toolchain and libraries of CodeWarrior 10.6.4
1,871件の閲覧回数
vigneshbalaji
Senior Contributor I
     I want to know the version of Toolchain and libraries that CodeWarrior 10.6.4 is using.
3 返答(返信)
1,517件の閲覧回数
ivadorazinova
Hi VIGNESH,
Version is 4.7.3
you can find it under C/C++ Build > Build Tool Versions > Version
I hope this helps.
Best Regards.
Iva
1,517件の閲覧回数
vigneshbalaji
Thank you Iva,
Now I want to know that if suppose I have a project using 4.7.3 version of GNU Toolchain which CodeWarrior 10.6.4 then if I
move a project Developed in CodeWarrior to KDS 3.0.0 Which uses version 4.8.4 will there be any problem? If so what kind of problems
will occur and how to fix it?
1,517件の閲覧回数
ivadorazinova
Hello Vignesh,
you are welcome. Do you have large-size project? If you have small project,is faster to create a new project.
There is created guide for importing project from CW to KDS and there is also described settings for tool chain
CW MCU 10.6 Processor Expert projects migration into KDS 3.0.0
Or you can take a look at the option how to change tool chain in KDS Switching ARM GNU Tool Chain and Libraries in Kinetis Design Studio | MCU on Eclipse
I hope this helps.
Iva
