The Debugger can not connect to the P&E device.
6,188 次查看
adrien_segura12
Hi !
I'm new on Codewarrior and i use a Universal Multilink (Farnell 2315740) to load my projects.
after a trip to make my project work on an other computer with the multilink, i tried to load my
project on my work computer. And then codewarrior send me this error :
Launching has encountered a problem.
ARM GDI Protocol Adapter : Can't connect. The Debugger can not connect to the P&E device.
I saw that i got the same problem if i diconnect the multilink. but, it seems to work, both leds (orange and blue)
are on, and i re-installed my drivers and codewarrior .
I noticed that this error occured not only on codewarrior.
Anyone has an idea of how to solve this problem?
Thanks for reading me !
5,954 次查看
ZhangJennie
Hi Adrien,
I suggest you refer this check list to shoot trouble:
Debugging Failure: Check List and Hints | MCU on Eclipse
Jun Zhang
5 回复数
5,954 次查看
ZhangJennie
Hi Adrien Segura ,
Please send us more information about your query:
1. Do you use demo board or customized board? part number?
2. Your CW version?
Have a nice day,
Jun Zhang
5,954 次查看
adrien_segura12
thanks for your reply ! I use CodeWarrior V 10.6.4,
my card is customized and used for a bus communication application.
I re-tried to use the multilink on other computer and other applications, it seems that i always have the same error message :
Any ideas? thanks for your answers !
5,955 次查看
ZhangJennie
Hi Adrien,
Jun Zhang
5,954 次查看
adrien_segura12
Thanks ! the problem is resolved !
To all people who have the same problem, the link upside is perfect !
Thank you again ZhangJennie, it was a hardware problem, but the steps of the link you gave were really helpful.
5,954 次查看
ZhangJennie
You are welcome!
