The CodeWarrior preferences file is read only or is currently in use
2,421 次查看
ashbc1
I have moved to a new account o the same PC/installation.   CW5.1 for HCS12 will not run under the new account, giving the above error.
2,030 次查看
ashbc1
Thanks you.  I have resolved the issue.   It is due to Administrator rights on the local machine rather than the just the domain.   Getting IT to add my new account to local Administrators solved the problem
2,031 次查看
ashbc1
2,030 次查看
Hello Ashley,
What about your system of PC ?
And what about the error , please take a screenshot about it , also the screenshot about" will not run".
thanks!
Alice
