Target Request failed:EPPC GDI Protocol Adapter:stop failed
2,365 次查看
Yangyajie
I use code warrior 10.5, mpc5604b for the chip and multilink universal for the emulator. When debugging, an error will be reported as soon as I press “pause”: target request failed: eppc GDI protocol adapter: stop failed
This error message will appear in some projects, but not in others。
2,356 次查看
lukaszadrapa
it looks like the debugger lost connection with the microcontroller in the meantime. Was the microcontroller reset? Could you check it by an oscilloscope?
Lukas
