Steps to flash image for fresh board using freescale codewarrior tap in cli prompt
1,590 次查看
harisankar1601
We are flashing the image using code warrior GUI application.It was working fine.
BOARD NAME - LA1224_RDB
Now we are trying to flash the image using freescale code warrior tap using cli prompt.Can you suggest any steps to flash the image using commands without using the GUI?
1 回复
1,571 次查看
yipingwang
Please refer to "Chapter 7 Flash Programmer" in C:\Freescale\CW4NET_v2020.06\CW_ARMv8\ARMv8\Help\PDF\ARMv8_Targeting_Manual.pdf
