Static library
Static library
2,460 次查看
martindusek
how to compile a static library in CodeWarrior for MCU Version: 10.2 Build Id:120126, that can be used in CrossWorks for ARM (GCC toolchain)?
Martin
标记 (3)
1,984 次查看
BlackNight
Hi Martin,
10.2 is pretty old, the actual version is 10.5. Things would be much easier for you if you would at least move to 10.4.
I used libraries with 10.3, and the following posts might help you to do the same thing with 10.2 (but not sure as I moved up to post 10.2 long time ago):
http://mcuoneclipse.com/2012/10/08/a-library-with-arm-gcc-and-eclipse/
Creating and using Libraries with ARM gcc and Eclipse | MCU on Eclipse
I hope this helps.
