Hello Dipika
Thanks a lot for contacting us.
In your CW8.3 project, please add the access path in for your SDK source code as below:
1) Open the CodeWarrior 8.3 and click Edit menu followed by selecting Preference item;
2) Click "Source Trees" under "General" panels on the left
3) In the Name edit box, enter: Embedded SDK Source
4) Click "Choose" button and select the path to the src subfolder of the SDK installation directory
5) Click "Add" button followed by clicking Apply button
6) Load your old SDK project and rebuild it.
If this does not work, please open Target Settings by ‘Alt’ + ‘F7’ key, and select ‘Target-> Access Paths’, on ‘Access Paths’, press ‘Add…’ button to add the path for your SDK head files.
Best Regards
Fiona Kuang
TIC - Technical Information Center
Note: If this post answers your question, please click the Mark Correct button. Thank you!
