Software debug written by corewarrior runs, and the power goes out
1,291件の閲覧回数
15258085388
Software written by corewarrior11.1 can be run with debug, as well as with debug turned off.But when the battery is switched on the program doesn't respond and that's why.Do you need any configuration
1,222件の閲覧回数
FelipeGarcia
In order to give you a better support, could you please give more details about your issue?
Which error are you seeing? If the MCU is not working when not debugging, I recommend you to print messages or toggle a LED to track the issue more easily.
I hope it helps.
Felipe
