S12XE Write to EEPROM and Debugger
4,746 次查看
rayhall
I have been testing writing and reading from EEPROM with the S12XE. The data is written and I can read it back. The problem is the debugger. It only shows the data in EEPROM memory just before you run the debugger again.
I have made a movie of what is happening in the debugger. In this test I write 0x4444 to EEPROM.
Ray.
4 回复数
4,482 次查看
ZhangJennie
hi Ray,
i checked your video, you want to refresh memory from 0x100000'G which logical address is 0x800.
i would suggest you enable "refresh memory when halting" option. this should solve your problem. see attached video.
can this help you?
Jennie Zhang
4,482 次查看
taofu
hi, Jennie,
I have followed your video, but EEE won't refresh when halting.
4,482 次查看
ZhangJennie
Hi tao,
I am surprised. This is a thread of one year ago.
If you also have this problem, please create a new thread for your issue. with this email attached:
- your demo project.
-please mention how to reproduce your problem step by step.
Jennie
4,482 次查看
taofu
Thanks, Jennie.
Data in EEE can be read by reading function, now. So this question is not matter now.
