Hello Dears
I'm working with S08 microprocesor
I have the next code lines, I'm trying to following the RM but its hard for me.
I need use stop mode (stop3) and then wake up via reset. I'm not sure if the Internal reference clock is 50Mhz or is 25Mhz
Use a PWM at 60Hz for set a intensity to a led
#define OVFCOUNT 50 extern unsigned char count = OVFCOUNT; //number of Timer Overflows before increasing the pulse-width extern unsigned char updown = OVFCOUNT; //0 for up, 1 for down void MCU_Init(void) { //Crucial (Stop mode configuration) SOPT1=0x20; //STOPE=1 to SOPT1 register to enable stop instruction SPMSC1=0x0; //Set to STOP3 without LVD and BDM modes, see table 3.1 on reference manual for more information //SPMSC2=0x1; //Uncomment this line for set to STOP2. // System Clock Init ICSC1=0x44; //Internal reference selected (50Mhz) ICSC2=0xC0; // bus clock to 6.25Mhz (50Mhz/8) } void configureMTIM(void) { //////////////////////////////////////////////////////////////////////////////////// // formula time =((clock divider)*(MTIMMOD register value+1))/BUS clock /// ////////////////////////////////////////////////////////////////////////////////// MTIMCLK = 0x08; // Bus clock (BUSCLK) witch is 6.25Mhz , Bus clock 256 divider MTIMMOD = 0x30; /* Count to 48 ,+1 */ //time 2.007 ms , ((bus clock divider)*(MTIMMOD+1))/busclock "bus clock =6.250mhz" } void FTM_Init(void) { //16-bit counter max:65536 so i cant get a 60Hz in this way // TPM clock = BUSCLK = 6.25MHz,channel operate in edge-aligned, Overflow Interrupt Enabled FTM1SC = FTM1SC_CLKSA_MASK | FTM1SC_TOIE_MASK; //PWM frequency = 60 Hz FTM1MOD = 375000000; // TPMclock/TPMxMOD = 6.25MHz/375000000= 60 Hz // Configure channel 0 to PWM mode (high-true pulses) FTM1C0SC = FTM1C0SC_ELS0B_MASK | FTM1C0SC_MS0B_MASK; // Pulse Width FTM1C0V = 187500000; // PMxMOD/TPMxCnV = 375000000/187500000, channel 0 set to 50% } interrupt VectorNumber_Vftm1ovf void FTM1ovfISR (void) { // The same problem un FTM_Init cause the 16-bit counter //Clear interrupt flag (void)FTM1SC; FTM1SC_TOF = 0; count--; if (!count) { if (!updown) //up counting { FTM1C0V += 3750000; if (FTM1C0V == 371250000) updown = 1; //when reaching 99%, change to down counting } else { FTM1C0V -= 3750000; if (FTM1C0V == 3750000) updown = 0; //when reaching 1%, change to up counting } count = OVF_COUNTS; } } }
I really appreciate your time, thanks for the help
解決済! 解決策の投稿を見る。
Hi Carlos,
Yes, it hard use the project of PE to no-PE project, I meaning you can do like this :
According your need create a PE project , it is simple and need little time only configurate the init .
Then refer to the generate code write your own project .
Best Regards
Alice
Hi Carlos,
If you not sure how configurate the clock and how to initialize ,you can firstly use the Processor Expert configuration , and there also have "help component "can check the meaning of the related compenet.
it is convenient . It is configurate like this :
The CPU clock select :
The FTM clock configuration :
Alice
If this post answers your question, please click the Correct Answer button.
Hi dear Alice
Good answer but... I'm need do the code like a library it will be use in another project, the Microprocesor that I use will be come a slave. In master microprocesor aren't in procesor expert.
I dont know if using procesor expert will works in the project without PEx
Hi Carlos,
Best Regards
Alice
Oh I see
I never thought that way, thanks Alice!
Regards.
