Related to codeworrior10 NPF file formation
leimengfighting
How to make an NPF file out of an existing LDF file in codeworrior10? Why is the Network definition option LDF file and Node name blank? I need somebody help .
ZhangJennie
HI Jackie,
I ever tested NPF file exporting feature, If I well installed the ncf plugin, there is no problem.
- What's your CW version?
- What's your LIN stack version?
- Can you please send me the steps of reproducing this issue?
Jennie Zhang
leimengfighting
  The problem has been solved.thinks for your help.
ZhangJennie
Hi Jackie,
That's good. You are welcome.
Jun Zhang
