Problems in the installation of CW 10.3.3.
11,424件の閲覧回数
admin
Specialist II
I installed the codeWarriorfor PA.
This is the error I recieve after trying to build an hellow world project:
**** Build of configuration Debug for project Lib_Time_measurement ****
(Cannot run program "C:\Program Files (x86)\Freescale\CW_PA_v10.3.3\gnu\bin\C:\Program Files (x86)\Freescale\CW_PA_v10.3.3\gnu\bin\mingw32-make" (in directory "F:\All_freescale_Projects_Version_0.9\Lib_Time_measurement\Debug"): CreateProcess error=2, The system cannot find the file specified)
THanks,
Yehuda
8 返答(返信)
11,136件の閲覧回数
addiyi
Hi Yehuda,
Please provide following information:
- Windows version and if is 64bit;
- Do you have UAC (User Account Control) disable (Never notify) or set as default;
Also, if UAC is disable and you didn't install CW as Admin, please try to reinstall it to other location then C:\Program Files. If this is not working for you, can you please attache the project you are using?
Adrian
11,131件の閲覧回数
admin
Specialist II
Dear Adrian
I succeeded in installing the CodeWarrior.
I have problems in the enclosed projects.
Yehuda
Dr. Yehuda Singer
Parallel Solutions Ltd.
www.llp.co.il <http://www.llp.co.il/>
Office: 972-74-7012159
Mobile: 972-52-2306-311
Mobile: 972-57-9457659
Text Box: Please consider the environment before printing this email The
information contained in this communication is proprietary to Parallel
Solutions Ltd. and/or third parties, may contain confidential or privileged
information, and is intended only for the use of the intended addressee
thereof.
If you are not the intended addressee, please be aware that any use,
disclosure, distribution and/or copying of this communication is strictly
prohibited. If you receive this communication in error, please notify the
sender immediately and delete it from your computer.
11,130件の閲覧回数
addiyi
Some time we have problem related to UAC settings, but is not the case now.
For your problem, please go to project properties (right click on project -> Properties), then go to C/C++ Build and make sure Use default build command is checked (as in attached file).
Adrian
11,130件の閲覧回数
admin
Specialist II
Dear Adrian.
We have the same screen and values as you have sent us.
Yehuda.Singer
Dr. Yehuda Singer
thereof.
11,130件の閲覧回数
addiyi
Your project have 2 configurations, Debug and Release. Indeed, on Release configuration the Use default build command is checked, but for Debug configuration is not.
If you use Build All (Crlt + B) option, both configuration will be build and for Debug you will get the error reported.
In project Properties -> C/C++ Build switch to Debug Configuration and check Use default build command is selected.
Adrian
11,130件の閲覧回数
admin
Specialist II
Dear Adrian,
Thank you for your answer.
Another problem:
Consider the statement: double clock_cycles = double ( sysconf(_SC_CLK_TCK
The symbols SCCLK_TCK is not defined in the new Linux library.
This symbols gives thefrequency of the clock.
Yehuda.Singer
Dr. Yehuda Singer
thereof.
11,130件の閲覧回数
addiyi
Include unistd.h in time_measurements.cpp, becasue the function and associated parameter necessary for sysconf are declared in this header file.
Adrian
11,130件の閲覧回数
admin
Specialist II
Dear Adrian,
Thanks,. This was the change when migration from version 10.2 to 10.3.3.
Yehuda.Singer
Dr. Yehuda Singer
thereof.
