Problem in Printing Data at higher baud rate using Uart
mdrasool_yadwad
when we use 115200.pngwhen we use 256000.pngHello,
   I am using K60 microcontroller and configured uart for printing into the putty(console). It is printing perfectly fine for lower baud rates upto 115200. Above this baud rate it is not working properly it is printing garbage . I have uploaded the images .May i know whats the problem so that I can correct it.
jingpan
jingpan
