Please tell me the Build error solution on CW(ver10.7) by miki
1,251 次查看
三木理人
Hi, my name is miki. I am using CW for the first time.please let me ask a question about the error when building CW.
When building a pmp file for EVA on CW, a bunch of errors (syntax, definition) are output as below(Please check the attached file). Does that mean that something's definition file is not enough? Could you tell me the solution?
〇CW version (10.7  i using )
〇pmp for EVA
     AN5327_SW_CW10
〇build error message
      Please confirm attached file.
1 回复
1,134 次查看
ZhangJennie
Hi miki,
Please send me a link of the project. I will test it from my side.
Thanks.
Jennie Zhang
