No breakpoints/disassembly for Assembly code
1,480 次查看
digisnapmark
Using Codewarrior for MCU v10.6.4  b.150416
I cannot seem to find a way to add breakpoints to assembly code. I can add them in C code with no problem.  I also don't get any disassembly listing for assembly code showing up in the 'Disassembly' window in the debugger.
Thanks, Mark.
标记 (1)
1,377 次查看
BlackNight
You need to set the breakpoint in that column on the left side of the view, see as well Assembly Instruction Stepping | MCU on Eclipse
I have seen as well cases where the view did not show the disassembly code: In that case I close the view and open it again. I'm not sure what is causing this.
I hope this helps,
Erich
