NXP Tagwriter - Write from CSV
1,611件の閲覧回数
chrisong_what
Hi Sir/Madam,
Good day to you.
Kindly check with you the CSV file if i want to add more records in a row, is it possible can do?
Thanks.
Christopher
1,531件の閲覧回数
IvanRuiz
Thank you for contacting us. I just checked your case; basically the app allows you to write comma separated values but not more than one record per row, this means that despite you write it either on CSV or "normal" format, you could only add one record per row, please see below for an example of the Comma Separated Value:
Have a nice day!
BR,
Ivan.
