NTM88 software verification
1,613件の閲覧回数
siddhant67
  • How to validate software written in CodeWarrior tool?
  • is there any unit testing, software testing tool available?
タグ(1)
1,603件の閲覧回数
diazmarin09
I hope all is great with you. Thank you for using the NXP communities.
Do you mean, validate your own project ?
Have you considered to attach to process?
To use this option, select “Attach to Process” from the IDE’s “Debug” menu. Use this option if you want to attach to a running board with minimal interruption. This option causes the debugger to perform these tasks:
  • Load ELF / DWARF symbols
  • Leave the target running
Note that once the debugger is attached, you must halt the target before the debugger can access memory locations or registers.
I hope this information helps.
David
