 ZhangJennie
			ZhangJennie
		from your screenshot, all the five items are color icons which means they are not fully installed
from the error messages, a certain item should be partly installed and has been recorded by CW.
I suggest you fully uninstall CW and remained install.
reinstall CW10.5, then install "MCU v10.5 Updates for MQX", "CW10.5 update". Please pay attention to the install sequence/
at last install MQX4.1.
see how it works?
Jennie Zhang
thank you ... i followed the same procedure in some other PC and it installed perfectly.....
( Even in my first PC its not , may be CCS i have installed. It might giving issue)
Thank you :smileyhappy::smileyhappy::smileyhappy:
 ZhangJennie
			ZhangJennie
		You are welcome! :-)
Can you tell me where exactly i can get MQTT header and neccesary files ? I want to MQTT for MQX.
 ZhangJennie
			ZhangJennie
		As I know there is a known discussion regarding to MQTT, see
MQTT client libraryMQTT client library
if above thread can not help you, to separate different subject, can you please create a new thread for MQTT related question? Thanks!
Jennie Zhang
thats really helpfull..
I forgot to menstio that im using GPRS modem(G620) and i need to implemet MQTT client .
 ZhangJennie
			ZhangJennie
see how it works?
Jennie Zhang
 ZhangJennie
			ZhangJennie
MQX 4.1 was developed to work with CW MCU v10.5. It has been tested and confirmed to work with CW MCU v10.6.
please
- uninstall your CW and MQX
- restart computer
- install CW10.5
- install CW10.5 update
- install MQX4.1
- restart computer
see how it works?
Jennie Zhang
i tried but no use..... even i tried with different PC. but no use.
MQX3.8 is working fine. But MQX4.1 giving issue
 ZhangJennie
			ZhangJennie
		did you install "MCU v10.5 Updates for MQX" as I highlight below? it's necessary.
Besides I also suggest you install other items I highlighted in purple.
MQX4.1 must be installed AFTER CW10.5 updates installed.
above steps work on many computers for us and customers. please double check.
Jennie Zhang
I installed CW10.5 first
And now i tired to install the updates.
The option which are highlighted in purple, installed without any issue
but the option highlighted in yellow color, giving issue.
