MKW24D board transmitter
1,864 次查看
vitorgabriel100
Hello.
I would like to know the approximate range (in meters) of the nxp MKW24D board transmitter. I would also like an indication of an external PA compatible with this board.
标签 (1)
标记 (3)
1 回复
1,801 次查看
stephanie_m
Please consider that this device is not recommended for new designs, you can use the Hardware Design Considerations and maybe use the KW41Z Power Amplifier Reference Design | NXP to complement your design , still, I would recommend you to use the KW21Z and use as well the KW41Z reference design.
Regards ,
Estephania
