MC68HC908 Assembly Language Guide
eepty
I am modifing a software for the MC68HC908. In the original software, there is a part which is written in assembly language:
void IROutput()
     byte tcount, delay, count=10, data, ptr=0;
      data = Msg[ptr];
      asm {
                  entry:
                     LDA #2
                     STA tcount
                     LDA #31
                     STA delay
                     BRA high
                loop:
                     BCLR 5, PTB   ; Clear the output
                     DBNZ count, next
                     BRA exit;
                next:
                     LDA #31
                     STA delay
                     SEC
                     ROR data
                     BCS ntdo
I have learnt assembly language long time ago, is there a guide for programming assembly language for this NXP microcontroller?
Thank you.
ZhangJennie
Hi Gary,
please refer this document
http://cache.nxp.com/files/microcontrollers/doc/ref_manual/CPU08RM.pdf
can this help you?
Jennie Zhang
