Linker sript file *.lcf
kleckerspur
is there better document for understanding *.lcf than AN4329.pdf ?
thanks
catalindemergia
I attached it.
Catalin
catalindemergia
Yes, in your CodeWarrior installation there is Help\PDF folder;
look for the StarCore SC3000 Linker User Guide document
It contains a lot of information on this subject.
Catalin
kleckerspur
thanks for your answer.
I can not find the docomuent in my 10.6 installation!
This are the files I have:
AN4902.pdf
CDE_RTOS_User_Guide.pdf
CDE_userguide.pdf
CodeWarrior Common Features Guide.pdf
Ethernet TAP Users Guide.pdf
EWL C Reference.pdf
EWL C++ Reference.pdf
Macro_Language_Reference_Manual.pdf
MCU_ColdFire_Assembler.pdf
MCU_ColdFire_Compiler.pdf
Microcontrollers_FAQ_Guide.pdf
MISRA_C_2004 Compliance Exceptions.pdf
MQXLite_RM.pdf
MQXLite_User_Guide.pdf
PEXCDEGETSTARTEDUG.pdf
ProcessorExpertHelp.pdf
Profiling and Analysis Users Guide.pdf
RTOS Adapter Developers Guide.pdf
Targeting_Microcontrollers.pdf
USB TAP Users Guide.pdf
Handwritten :-)
catalindemergia
I attached it.
Catalin
kleckerspur
this is super.
I found the file using the internet !
