Link Order View-code warrior
2,804 次查看
georgemathew
The Link Order view of the Project window shows information about
how the IDE will compile or link the final output file for the project's current build
target.
The IDE links the files in order from top to bottom. For example, if file B depends on
file A, make sure that the Link Order view lists file B below file A.
what it means
5 回复数
2,603 次查看
ZhangJennie
The IDE links the files in order from top to bottom in CW "Link Order" tab.
the file on the top is linked before the files on the bottom.
thus with this link order,  the variable/function in the prior linked file will be recognized first.
"link order" defines a priority that searching variable/function in files.
Jennie Zhang
2,603 次查看
georgemathew
if the link order is wrong, is it results in wrong output?
2,603 次查看
ZhangJennie
yes.
2,603 次查看
Carlos_Mendoza
Hi George,
Could you tell us which MCU and CodeWarrior version are you using?
Thanks in advance!
Carlos Mendoza
Technical Support Engineer
2,603 次查看
georgemathew
codewarrior 5.1,  controller-MC9S12A128
