Licensing for Flash programmer as Standalone Programmer
1,407 次查看
vkhungund
I am currently using the CodeWarrior 10.7 with Evaluation License and use the Codewarrior only for Flashing the .sx files. I wanted to know if there are any License requirement for CodeWarrior-Flash programmer after expiry of the evaluation License.
Thanks!
1,399 次查看
ZhangJennie
Hi.
The code size limitation is related with target part number. But you can test it byself.
1. backup your license.dat file under your CodeWarrior install
2. reopen your CodeWarrior. This is to mimic CW evaluation license expiration state.
3. Test if the sx file works with the programmer?
Jun Zhang
