Is it possible to view memory information(stack, heap) while debugging the code in CW10.3?
1,925件の閲覧回数
Embionics
I am new to codewarrior development studio.
In my project I am using freertos. I am facing some problems while allocating the memory to the tasks. Is there any possible way to view the memory resources(stack, heap etc.,) dynamically while debugging the code? Your information will be helpful for me
Durgesh
タグ(1)
1,521件の閲覧回数
BlackNight
Hi Durgesh,
not for the heap, and not in CodeWarrior.
For Eclipse/GDB (e.g. Kinetis Design Studio) there is a plugin to see the task information and queues. See
http://mcuoneclipse.com/2013/08/04/diy-free-toolchain-for-kinetis-part-5-freertos-eclipse-kernel-awa...
As for the heap, I use the approach to show it in my application/shell. As I don't know which heap problem you are facing, here are some other articles:
http://mcuoneclipse.com/2013/07/10/freertos-heap-with-segmented-kinetis-k-sram/
FreeRTOS, malloc() and SP check with GNU Tools | MCU on Eclipse
I hope this helps,
Erich
