Installing codeWarrior in Ubuntu 14.04 LTS
ashwingandhi
can  any one tell the Procedure to install CodeWarrior Development Studio for Power Architecture v10.5.1 - Linux to install in Ubuntu 14.04 LTS.
i tried to follow steps given in readme file to install but its not working..
jinyu_zhang
Fresh Out Contributor
I've installed the version into my Ubuntu 16.04. After you do all the steps in the README file, you need do one more thing. Change directory to the {installed}, and run the install_deps.sh file in the terminal or/and run the detect.sh to verify your completement.
addiyi
Your Ubuntu 14.04 is 64bit version? If yes try the steps below:
- follow the steps from Readmee file, Chapter 2.14 Ubuntu 13.10 / 14.04 / 15.04 / Linux Mint 15
- run ./setuplinux script
- run ./runinstall and provide the error/msg
Adrian
