How to use software interrupt/ timer interrupt on KE06Z
2,419 次查看
eyeow84
I am using FRDM-KE06Z (MKE06Z128VLK4) to control hi and low state on few I/O pins. I am using CW 10.6 Processor Expert (PE) to generate code TimerInt_LDD. I want to set 3 I/O pins to HI during state 1 for 3 minutes, and set/toggle them to LOW during state 2 for 3 minutes. And maintain this loop over a period of time or infinite loop.
I am still exploring the options to make this works. I found that one of the possible ways is to use TimerInt_LDD? However I don't have any working example by using this TimerInt_LDD component and the example given in CW help is very insufficient.
thanks.
2,307 次查看
ZhangJennie
Hi Lee,
I suggest you use component PPG_LDD which has method to change period and duty cycle during program running.
Jennie Zhang
