How to uncheck "stop on first build error" box
1,301 次查看
brianlarsen
How do you uncheck the "stop on first build error" box under C/C++ Build->Behavoir. It is grayed out, and see no reason why I would not be able to uncheck it.
标记 (5)
1,170 次查看
catalindemergia
This option is grayed-out because it is referring to an external builder. It makes sense
only when the build process is controlled internally by CodeWarrior, only then we can stop
the process after the first error, otherwise CodeWarrior cannot stop an external program.
I agree there is a little inconsistency here, maybe that check-box should not appear in the GUI
when Builder Type is set to External Builder (see the first tab - Build Settings)
regards,
Catalin
