How to save the Console Log text into a text file using TCL script
4,949件の閲覧回数
Adrianca01
Hi is the a Tcl script that can save the console or debugging shell log once it done Flash into a text file
4,920件の閲覧回数
EdwinHz
I found another community post that could prove useful for your inquiry. My colleague Jorge Gonzalez links several tutorials about scripting and Command Line programming/debugging that I think could be of use. Here's the link to the post:
https://community.nxp.com/t5/CodeWarrior-for-MCU/TCL-Script-in-Codewarrior-for-MCU/m-p/295555/highli...
Edwin.
4,921件の閲覧回数
EdwinHz
Edwin.
4,906件の閲覧回数
Adrianca01
Hi I follow all the steps from the link and i cant seem to find a way to save the Console Output result from the flash into a text file. I followed the next solution
https://community.nxp.com/t5/CodeWarrior-for-StarCore/Log-Console-Output/m-p/183525/highlight/true  But it does not save.
That is the information i want to save into a txt file once it is done with the Flash Operation.
Thanks for the help!!
