How to program eeprom using code warrior 5.9 tools or any others tools
5,083 次查看
pier-luc_rosa
my microcontroller is MC9S12DG128VFUE and we have code warrior 5.9. How to program the eeprom or erased it ?
7 回复数
5,068 次查看
ZhangJennie
Please see attached demo code.
It's for DP512 but the method is the same as DG128.
Hope this will help you,
Jun Zhang
5,055 次查看
pier-luc_rosa
Is it possible to use WL command from Code Warrior Debuguer instead. Why it doesnt persist after reboot?
5,048 次查看
ZhangJennie
Besides the demo code method, you can define a const data in EEPROM address. The const data are burned to EEPROM during download the code.
BUT, you can't revise EEPROM with debugger tool.
Hope this helps,
Jun Zhang
5,045 次查看
pier-luc_rosa
I found a tool called prog12z wich is suppose to be able to do it, not sure how it work I will give it a try.
5,030 次查看
ZhangJennie
prog12z is P&E programming tool. As I know It can program eeprom. If you have any question regarding to prog12z, please contact P&E community.
4,997 次查看
pier-luc_rosa
to connect to the device, what gnd and vdd should I use ? I am measuring 2.9V on VDD1 is it suffisiant ?
4,993 次查看
ZhangJennie
Your follow up question is no longer about CodeWarrior. Please create a thread to 16bit MCU space.
https://community.nxp.com/t5/S12-MagniV-Microcontrollers/bd-p/16-bit
The 16bit HW engineer will help.
Jun Zhang
