How to open .abs files
2,064 次查看
jixiangli
Hello everyone,
            In the CODEWARRIOR programming environment, after the new project is compiled, the.abs file will be generated. What software can be used to open the.abs file? Please make a recommendation. Thank you very much!!!
1,873 次查看
Hello jixiang li ,
You can try to open it using UltraEdit .
Hope it helps,
TIC
1,873 次查看
jixiangli
OK,thank you !
