How to fix the issue occured while opening codewarrior 10.6
2,832 次查看
chennamdhanushm
5 回复数
2,686 次查看
chennamdhanushm
Thank you for your concern Jennie Zhang.But I'm getting not only the scalability issue but also i couldn't create the new project file.Hope i get solution for this.
Thanks in advance!
Dhanushma
2,686 次查看
ZhangJennie
Hi Chennam,
I would suggest you remove your .metadata folder of your workspace, then try create new project again.
You may need backup your .metadata before the removal.
Jennie Zhang
2,686 次查看
chennamdhanushm
I'm using MPC5643L controller
2,686 次查看
ZhangJennie
Besides, Please check if this article can help you
Eclipse Editor Scalability | MCU on Eclipse
Jennie Zhang
2,686 次查看
Carlos_Mendoza
Could you tell us which MCU are you using?
Thanks in advance!
Carlos Mendoza
Technical Support Engineer
