How to fix the issue occured while opening codewarrior 10.6
chennamdhanushm
chennamdhanushm
Thank you for your concern Jennie Zhang.But I'm getting not only the scalability issue but also i couldn't create the new project file.Hope i get solution for this.
Thanks in advance!
Dhanushma
ZhangJennie
Hi Chennam,
I would suggest you remove your .metadata folder of your workspace, then try create new project again.
You may need backup your .metadata before the removal.
Jennie Zhang
chennamdhanushm
I'm using MPC5643L controller
ZhangJennie
Besides, Please check if this article can help you
Eclipse Editor Scalability | MCU on Eclipse
Jennie Zhang
Carlos_Mendoza
Could you tell us which MCU are you using?
Thanks in advance!
Carlos Mendoza
Technical Support Engineer
